Nous sommes le Lundi 09 Février 2026 9:40
Poster un nouveau sujet Répondre au sujet  [ 154 messages ]  Aller à la page Précédente  1 ... 4, 5, 6, 7, 8  Suivante
 Sujet du message: Re: English 106 xsi
MessagePosté: Vendredi 30 Décembre 2016 10:51
Great Job !! :o
For wonderful results :kakashi:
MessagePosté: Vendredi 30 Décembre 2016 21:50
:bien: :bien: :bien:
Travail de malade. :kakashi: Good Job
MessagePosté: Vendredi 13 Janvier 2017 19:28
:bcry: :inlove:
MessagePosté: Dimanche 22 Janvier 2017 20:51
Evening all....
The dash has been over to Ireland for some TLC at the hands of DieselDave.. (worth a follow on instagram)
I have to say its a f**king good job!!
And after a bit of wrestling it was in place (still a couple of brackets to attach it to the cage) the dash section of harness was clipped in and it was starting to look like a car again...
MessagePosté: Dimanche 22 Janvier 2017 21:04
Are you keeping the stock heater ? If not, what are you using against mist ?
Amazing job as usual :bien:
Ma chaine YouTube
Ma page Facebook
MessagePosté: Lundi 23 Janvier 2017 8:11
Stock heater has gone.. i think it will be a heated screen and see how that copes..
If its not enough, the ducting under the dash is still in place so i may look at fitting a small aftermarket water/air heater blower to assist...
MessagePosté: Dimanche 29 Janvier 2017 20:20
So.. a casual 67hours at work this week meant not much time for the car.. but after a sunday morning double time stint i popped down the social club for some tinkering..
Pulled up a rug, mother made me a coffee and i set about the discs:
Resulting in:
I did also fit up the harness shoulder straps according to:
And started fitting the gearshift linkages thru the bulkhead - unfortunately a flat phone battery has limited pics for this update....
MessagePosté: Dimanche 05 Février 2017 7:04
More fitting up done...
MessagePosté: Dimanche 05 Février 2017 7:33
MessagePosté: Lundi 13 Février 2017 15:40
Very beautiful work, your front is amazing. She 's going to bring down the chrono your 106
MessagePosté: Lundi 13 Février 2017 21:00
Just : wow !!!
MessagePosté: Jeudi 16 Février 2017 7:48
Thankyou all very much....
Theres been a few delays this week, odd sized bearings/broken bushes/STILL waiting on windows.. but i will try to update again soon...
Stu
MessagePosté: Samedi 18 Février 2017 2:07
Nice job.
MessagePosté: Dimanche 26 Février 2017 20:25
Alright peeps...
So.. decided to give the steering rack a bit of a spruce up.. it was stripped/blasted/powdercoated and then just pop it all together..
Yeah... because its always that easy isnt it!?!
The needle bearing was a bit notchy (knackered) so i popped up to the suppliers only to be told they were unavailable.. a bit of head scratching and we decided the french were being typically awkward in using a custom bearing and to drop down on the OD to the nearest std size and i'd machine a sleeve to hold it in place:
Once that was all done I had a shiny rack:
So.. the pedalbox went in.. the rack went on and i started on the steering arms...
Aaaaaand another issue arose:
Ya see these little rod end spacers:
I found 3..
Guess how many i needed??
Yesssssss 4.. thats right!!!
So, after much swearing and cursing i decided to make 1... some bar was thriwn in the lathe and i fired up the Ateam music...
And just like Hannibal and the boys... i love it when a plan comes together!!:
Colomn was bolted up.. arms fitted.. we had steering!!
I did start getting pedals attatched but was running out of time and correct sized bolts..
MessagePosté: Mercredi 01 Mars 2017 18:45
Amazing work as always :bien:
Ma chaine YouTube
Ma page Facebook
MessagePosté: Vendredi 10 Mars 2017 8:01
Another forum asked a bit about the steps involved with fabricating some of the stuff... so i took a few step-by-step shots of this grar linkage bracket...
To start off, we have 2 pieces of 1.5mm sheet folded into channels.. some laser cut discs.. and a couple of bits of tube...
The discs were welded onto 1 end of the tube to create a sort of bucket with a hole in the bottom.. the channels were welded together to create a thinwall box section.. holes were cut for the tubes and the whole lot bolted down to a jig plate
The ends of the box were cut and shaped to follow the tibes nicely:
Another piece of channel was pressed, the end shaped and the whole lot was welded up:
Left to cool, powdercoated.. and fitted up:
I also fitted the bootlid and checked the thermoformed rear screen for fit as thats being bonded in Saturday..
The workshop at my folks unfortunatly has been inhabited by bats so the ClassicAdditions cover was brought out of the toolbox.. but first i blew all the dust off and took a couple of 'reflection' shots.. please remember the car is still straight out of the paint booth and the finish is as it came off the gun, it still needs a final polish...
And then tucked it up until the weekend....
MessagePosté: Dimanche 12 Mars 2017 15:22
Anyone that knows me, (and my previous poor luck) will know i'm quite particular nowadays in who i let work on my car...
Sean (bespoke wiring solutions) did a fantastic job on the wiring..
Zane (ZLS) absolutely mastered the painting..
Dave (flockitanway) has nade the dash look stunning
And to that list i can add..
Russ Davis (ginge) (ultimate windscreens) to that list.. the guy drove nearly 2 hours to fit the glass and i'm so happy i found/chose him.. his attention to detail and knowlege is first rate and his results are first rate!!!
The windows themselves are hardcoated items (rear screen is also thermoformed) and are from MaxiMotorsport.. fantastic quality!!
So happy!!!!
I also got around to finishing the front brake pipes and fitted the stainless brackets up in the arches..
MessagePosté: Lundi 13 Mars 2017 0:00
MessagePosté: Lundi 17 Avril 2017 20:08
Alright folks??? Everybody good????
Got the rear suspension (and some other bits) blasted:
That lot got Zinc plated:
Rear beam assembled got powdercoated:
Made sure underneath was looking FRESH!!!!:
Rear trailing arms were treated to new seals/bearings and fitted up:
Hung the doors on:
Stripped the wiper assembly down to its bare bits and gave it a blast/paint:
And that's about where i'm at... out of date loctite kinda cut today short but fingers crossed it'll be rolling next weekend...
MessagePosté: Mercredi 19 Avril 2017 12:34
